8
8T4Gold
Well, finally it is time to work on the Vette.
Some time ago I read that a common problem was a battery that goes dead because of the ECM. This car has had someone hacking the wiring because the battery sometimes goes dead.(good battery) The radio has been changed,(cut wires under the dash) Horns wired wrong(one green wire to ground) fan jumped to run all the time (so as to stop overheating)
As a result, I would like to start with a good ECM, and rewire all that is wrong. What is the recomended ECM, and where do I get one?
Thank you to all who respond. Al
