D
Deusxmachine
Are there any negative effects that come from removing the egr from the car. I have a 1990 coupe.
you may run into a pinging condition because the combustion temp.will go upDeusxmachine said:Are there any negative effects that come from removing the egr from the car. I have a 1990 coupe.
P-38F said:Yes the exhaust temp. is hot ,but is also already burned. It is used to take up space in the combustion chamber ( instead of more O2 and fuel only less of it can now be burned) because there is now less fuel and O2 drawn in the combustion temp. drops.
