joli
This is the first part that I am having a hard time finding. I have an 82 with cross fire injection. The engine had been idling high all of the time at 1,000 rpms, I've got it down to about 700 after making what adjustments that I could, but to me it is still too high. You may know that with the cross fire there are no idle adjustments, at least none that I am aware of and there are many emmision parts that may or may not have anything to do with the high idle. While snooping around under the hood and testing the EGR valve I notied that the valve goes up and down freely and when the diaphram of the EGR is pushed up the idle goes to where it should be, so I traced the vacuum hose to what I've found to be the EGR Vacuum Solenoid and noticed that one of the two vacuum hoses that are connected by it that 1 of them was split at the conection and the solenoid is so old and brittle that when I went to repair the split it was beginning to fall apart in my hands. If you have any leads on where I can find the part (OEM#199712; 1997925) it certainly would be greatly appreciated. They use to have them at Auto Zone, but they no longer have them. Thanks all, and have a great Christmas!
;help
