JOV
Has anyone had this problem, my 2000 C5 that I bought new the passenger side door power window and auto lock quit working then as I headed home the DIC displayed Reduce Engine Power, shocks inoperative, low fuel, sevice tcs service tire moniter system, ect, ect, I shut it down then retrieved about 30 codes all starting with a U and ending with an H example U1016H. I restarted the engine and all was back to normal except the functions on the pass side door. I opened and closed the door 3 times and all the elect. fuctions returned. My optima battery is 3 years old and voltage is 12.5 and has not failed me in the years, Connections are clean and tight at the battery and at the PCM in the footwell and fuse box. Maybe my battery is going bad or a faulty ground !! Any advise would be welcomed and thanks in advance !!!!!
