N
ND67
I have a few electrical issues with my 1965 that I can’t figure out. I think they may be related but not sure.
First, the battery (new) will not last more than four days if I leave the car parked. Since I drive it only on weekends I end up having to jump it every week. The only thing running is the clock.
Secondly, and this is the hard one, every few times I drive the car it hesitates and misses when I try to accelerate. So if I’m sitting at idle the car runs fine, when I put it in 1st and give it gas it goes along ok but when I shift to second or third and really give it gas the engine will falter. I let of the gas and the car idles fine.
I’m wondering if this could be a poor ground somewhere but I have no ideal how to check. To make this more challenging, the 2nd problem doesn’t happen every time I drive the car. On Saturday I took the car out and ran it hard. It ran great. On Sunday I jump in the car and get to the end of my street and it starts faltering.. sort of like a car with bad or old fuel.
I can’t figure it out. Can someone tell me how many and where the ground straps are (or should be). Also, the positive battery post has felt around it but the negative does not. Could it be that the neg batt cable is close enough to the metal battery retainer (top of battery) to be causing problems?
I have a Voltage Meter but not a light. I’m no electrician but if there is something I should check please advise.
Thanks,
ND67
Thanks,
ND67
