8t7vette
- Joined
- May 19, 2004
- Messages
- 8
- Location
- Space Coast, FL
- Corvette
- 8T7 Black Z52 Coupe GreenWood gfx & 1994 Coupe
Well I was glancing at the installation instructions for the Abbott Electronics Ratio Adapter I picked up to correct the speedo and odo for the 3.75 gears as well as the 275/40's on my 87. The instructions say to tap into the VSS sensor wires no more than 6 inches from the speed sensor. Uh, I'm not sure if I want this thing sitting in the tunnel where it can be affected by the elements. Anyone installed one of these? Where did you install it? I'm wondering if I can mount or put it inside and run the wires through a small hole to the sensor area?
Toby
Toby
