wells
Working on 1989 c4 vette , ther are 2 wires at the vehicle speed sensor on tail shaft housing of 700r4 auto-trans (yellow -400 v.s.s. high and pupple -401 v.s.s. low ) which wire would I use to connect a Abbott Electronic Ratio Adapters (white wire signal in from the speed sensor ) and (blue wire out of Abbott to E.C.M. ) . Ok here is my own answer, the yellow wire no. 400 from the v.s.s. is the high pulse to the E.C.M. use this wire to connect the ( Aboott Ratio Adapter ) it will give you hundreds of ratios for if you change gears in your Dana 36 or 44 or do a wheel size change . Your speedometer will be corrected . Can buy at Ecklers .
