1
1DOWN6TOGO
HELP!
had major power loss this weekend. checked all of my cylinder pressures. significant pressure loss on 6 of the cylinders made me guess it may have been a blown head gasket.
took off the heads. i was right. blew the driver's side head gasket.
the gasket membrane between the middle two cylinders was shot. and i had a large piece of piston chipped off of one. looks like she had a heart attack. so now my baby is going into open heart surgery, this weekend.
i'm pulling out the engine and replacing the one piston and heads and head gaskets.
i could really use some advice on heads. the ones i had on were 882, i believe that was stock. i think i definitely shouldn't be running on stock heads with all of the compression my stroker puts out and i'm assuming it would run more efficient with my xe268h comp cam if i had a different set of heads.
i really need recommendations for heads. there is a swap meet in town this weekend and i'd like to check around for a good set, but i don't know what to look for.
HELP ME! PLEASE!!!
thanks
sam
HELP ME! PLEASE!!!
thanks
sam
