fill
New member
Having trouble with my L98 surging. When engine is cold, it runs good, no surging. After running for 10 to 15 minutes [ well after engine temp has come up to normal ] it will start to surge or '' loop''. I replaced the I.A.C. last summer ( about 5000 mi. ago). The surge started about mid June this year (2009). Since then I have relaced the throttle position sensor, the E.G.R. valve, ajusted valves, checked timing, and ran some fuel injector cleaner ( Lucas ). None of these made a difference. I also would like to upgrade the throttle body. Can anyone tell me the stock size in mm? Any thoughts on a BBK 52mm throttle body? I would like bolt on with no special modifacations.
