MarkWD
New member
I'm at a total loss over this one. I've had idling problems with my L98 and took it to Pep Boys. They said the throttle arm was slightly bend (though that seems impossible), fixed it, and now it is better, although the automatic choke does not seem to function. Regardless, when I started the engine at Pep Boys, the display blanks out after the engine is started. I showed them and they shrugged, saying they don't see how they could have affected it. Since then I've seen C-12 code (which shows there isn't a problem), then 1.0 with three dashes to 4. to 1.0. I've checked all of the fuses and they are fine. It displays properly before start and after engine shutdown, but not while it's running. The latest code I saw was H41 then 1.0 to 4. to 1.0. I've wasted a ton of money at the dealership trying to resolve other issues with no success. It has to be something simple. ANY help would be greatly appreciated.
