L
L82BLACKSHARK
suppose, just suppose i wanted to change the carb, intake and add headers to this newly rebuilt L 82 engine. i'd want the headers to have spark plug clearance so as not to burn the wires and cook the engine compartment.also to adapt to the dual pipes.
the intake on now is not the same as the L 48 engine intake. which new intake will be better from 1500 to 6000 and still give me hood clearance? the carb, big question. holly use to make a spread bore to replace the q-jet. i had good results with that one in the 70s. should i do the q-jet or do a new holly? need some ideas for this job, if i do it.
lets go guys, this is your chance to spend MY money.
if it sounds right, i just may do it.
