Tepot
- Joined
- Sep 13, 2005
- Messages
- 307
- Location
- Moncton, NB, Canada
- Corvette
- 1974 Metalic Blue L-48 Coupe 4 speed
Hi guys,
I really need you help on this one.
Last year I've got my car on the dyno and got 225 Hp at the wheels. This year I've installed brand new Patriots cylinder head part # 2181 64 cc aluminium.
Then Put the car on the dyno, what do I get? 225 HP at the wheels. What the f***k just happened? I had the smallest cylinder heads a L-48 engine could come with. There is no way I shouldn't gain a good 40 HP at the wheels.
I know at the dyno, we could see blue smoke coming out of the exaust at High RPM's. We got a full dyno tune up on my car and could only come up with 235 HP at the wheels. the guy at the dyno told me that the engine was probably warn because this engine should be pusshing 300 Hp at the wheels.
Here's my setup
350 L-48 chevy engine
Comp cam 268 Xtreme Energy Hydrolic flat tappet
Edelbrock performer EPS intake
Holley 770 cfm street avenger carburetor
Patriot performance cylinder 64 compression chamber part # 2181
running on headers and chambered exaust. true dual exaust
Now one thing I should mention, since I've put these heads on. I'm getting backfires coming throught the carburetor.
Is this a distibutor problem? I had the car timed correctly, changed vaccum advanced canister, timing cap, wires etc... I have an electronic pertronic conversion in the distributor as well. The car works really good when I drive besides those backfires once in a while through the carburetor. But the power is just not there. I should have more condisering the parts combination on this engine.
And by the way, I've checked compression in my cylinders and I have 150 psi in each cylinder. Should i have more? Is my engine really warned out?
Please help
Here's my setup
Please help
