1974vette
To start off, its been a while since i've been around. Its good to be back.  I've tried searching on this but i couldnt find an exact answer.  In the last year and a half, I've had the tired 350 in my vette replaced with a GM crate engine.  Its nothing special just a 250 or so hp crate engine.  When it was replaced, plugs, wires, distributor cap were also replaced.  It has a new holley 650 as well.  I havent driven the car in a while.  When i went out recently to drive it, it seemed to stumble pretty badly so i figured it was bad gas. i burned the gas out of the car and replaced it with premium.  The car seems to run fine but during 45-60 mph i can floor it and it barely does anything. it seems like the car falls on its face. then from about 70-80 mph, the car runs like it should.  I know around this past april my dad was messing with the carburetor adjustment screws and he doesnt exactly know what he's doing.  I'm wondering if this is attributing to it running rough? I'm planning on checking and replacing the plugs soon. I'm going to run AC delco plugs.  Which ones should i get? i have no clue which gap i should get, etc. Also, if any of you have any links that details the process of tuning a carb, i'd appreciate that also! im looking to get this car reliable. Thanks again for the help!
