There was, years ago, a post that referred to a study from a Pontiac fuels engineer.  They took a ratty, injector-clogged TPI and found that TWO tanks of good, detergent gasoline cleaned them up as well as the injector cleaning products/services.
Doc, your theory was that the injectors were not fully closing, which would make the engine run richer, not leaner.  That is inconsistant with your valve burning statement.  If there is unmetered fuel (leaking injector) getting in, the ECM will 'hunt' in all RPM ranges,  trying to adjust the mixture.  That is why my engine did it and probably why VetteBoy's did; both cases due to unexpected (not in the fuel tables) sensor inputs.  Both of our engines were intentionally modified; yours is modified, but not intentionally.
What's the worst case here?  You enjoy and relax with your gal, enjoying two tanks of quality Vette time, while cleaning your injectors; possibly saving the cost of replacing them.  There could even be fringe benefits!
I'd submit that ANY car that gets so little drive time, will suffer some consequences and you'd be hard pressed to find a forum for whatever car, as helpful as this one.
I have mixed feelings on the fuel filter, but they are cheap and rather easy to change.  A fuel pressure gauge would tell you if there is restricted flow.  I would ensure that your experiment with fuel pressure has you setting it back to factory specifications for your stock engine.
Go drive, buddy.
