T
Tobben
The above title seem to describe my problem well. During hard acceleration it may loose traction. So it doesn't lack power. But during normal acceleration it stumbles. It doesn't run perfect at idle neither. Anyone has experience with this? I have installed new plugs, plug wires is ok, new distributor cap and rotor, new air filter, checked injector ohm's ok, new coil wire. The left rear o2 sensor wire is cut of. I'm not sure this sensor will make my engine stumble, as it's not a primary O2 sensor. A GM mechanic was scanning my vette couple of weeks ago, it didn't have any troublecodes and he said the o2 sensor was working. The instrument information is out, so i cant read codes from it. But yesterday i was reading emission values from a emissioncontroll tester, and the CO was 2% Lamda between 1-0.9 and HC 13. The O2 went below 0.6% during 3000rpm.
Any advise or information would be most appreciated
Been working so long on this corvette now and there is so much to do:eyerole
