T
tir
I have a C5 2002 with 1500 km on it and i have problem with a tick noise from the engine. I have seen in the tech center that it may be caused by following: The O-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
How can i tell if i have this problem? Will the engine take oil? Or can it be the "Piston slap" problem? The noise is only there when the engine is cold. Is it safe to drive the car or can the engine get damaged?
