Jeff Farrar
Active member
Well, I finally got everything running great after working on various items this spring. I was coming home from my first cruise and decided to open her up a little. When I say I little I mean a little, 4500 tops. Right after that I started to hear a loud rpm related ticking sound. I let the car sit for a week hoping it would go away. No such luck. It started ticking again right at start up. It was really hard to isolate were the noise was coming from but I think it coming from the drivers side. I had my wife listen also and she confirmed the same with the stethoscope. I had the valve cover off and installed the clips to try and narrow it down and all the rockers "looked" fine. I also pulled the plugs out on that side and with less than 100 miles on them, number three looked a little gray while the others looked fine. Just for fun, I turned the engine over without the plugs and didn't hear the ticking or any other odd sounds. Not sure what that would eliminate.
Before I try and adjust the values on that side, what tests can I try to narrow down the source of the ticking? One manual recommend to put a .020 feelers gage between the rocker arm and the valve to narrow down a lifter (if that is what it is). I didn't try it yet, I just wanted to step back and not do too much before collecting more information first. "IF" it was a lifter, what could I try before I replaced them.
Big thanks in advance!
