Engines
Rod Brown
L.A.,CAL.
2016 Blacki Sting Ray
I have a 06 Coupe and I was wondering if the block in the coupe and the Z06 are the same? If not,what are the differences? Thanks,Rod
jhecox
Auburn Hills-MI
2016 Corvette Racing Yellow, Z51, OURS C7
I'm not an expert. But I believe the LS2 is 366 cu. in. and the LS7 is a 427 cu. in. That doesn't mean that the motor mounts couldn't be the same, but I would dout it.
Hecox
BlackZ51Vett
Vail, Arizona
They possibly could be, the difference in cubic inches being a different bore and stroke..:confused ....
jhecox
Auburn Hills-MI
Again, I'm not for sure. But... the LS2 is a "small block" and a LS7 is a "big block" so I would think they are different. Posibly just a different motor mount would allow it to bolt up. Again, there may be a difference at the bellhousing also.
Where are all the "experts" at? :W Someone in the "know" needs to answer this question. ;shrug
Sorry I'm just a dummy. ;help
Hecox
Gorgon
Philadelphia, PA
None
Again, I'm not for sure. But... the LS2 is a "small block" and a LS7 is a "big block" ...
Hecox
The LS7 is a 427ci small block. I'm sure someone will show up with the answer soon enough, but I'm doubtful that the blocks are the same.
Leon
c4c5specialist
Technical Advisor
New Haven, Ct. USA
Nope, but someday.
HI there,
Externally, they are not much different in visual comparisons, but they are totally different internally.
As those have mentioned, dry sump lubrication, bore and stroke, and almost everything internally is different.
Allthebest, c4c5
