Hi all. New to the site and new to the Corvette. I will try to keep this short and to the point but want to add all necessary info. The car is a 1994 lt1 with 80k original miles. I bought in April of this year. From what I understand is that the car was entirely stock except for a new fuel pump last year. The car starts right away every time and seems to idle fine (about 700 rpm). About 2 months ago when the weather started to get warmer I would run the AC and all was good. But at some point I noticed that when I came to a stop the idle would get erratic and bounce from 700-1400 or so rpm. That happened one time and was fine after that. I installed a cold air intake and still all was good. About a month ago (give or take) it happened again but I also felt the car lunge like it wanted to go while I was holding the brake (car is an auto btw). Did some research and found some info about the IAC so figuring it was 20 years old I replaced it. Car ran fine for a few days and then 3 days ago I am coming home with the AC on and coming to a stop on the freeway the idle starts bouncing and the car actually died on me (that was a first). But it started right up. Still stuck in traffic I alternated between drive and neutral to keep it running. It seemed a bit better in neutral. Off idle and accelerating was fine. Drove another 7 miles at high speed with no problem. Got about a mile from home and a new symptom. While accelerating from a stop to about 40mph the car was bucking a bit. Got it home to the garage and while sitting there the idle was still bouncing. Threw the code reader on and with no check engine light on I got a 43. From what I found that is a knock sensor. I don't think that would be the cause of my problem but a symptom of the real problem. But hopefully someone on here will know better tan me and have an idea.
I took the car out today for a short run and it was fine with and without the AC. However it is a cooler day herein Denver and the temp gauge never got over 200 degrees. I have not gotten a FSM for it yet but I will be. I have worked on cars for quite some time and am not one to just go throwing parts in until it is fixed. So if anyone has some insight as to what the problem may be or where to start I appreciate it. I have looked at past posts and haven't really seen a problem quite like mine. From what I have found on the web it seems there a some who just replace plugs, wires, computers and everything else until it works or they give up.
Sorry for the long post but thanks if you took the time to read it.
Oh I forgot to mention the previous owner was good about maintenance and stated they did do a tune up last year. Plugs, wires, cap, rotor.
