hzl6cm
I've done a search on the forum that turned up some information but I was still unable to locate the VIN that should be stamped in to the frame on my '70 Convertible. One thing I read indicated that it should be above the rear shock mount on the driver side. In another place I found a picture of one and irt seemed further back. I tried using a small wire brush, sandpaper and carb cleaner but couldn't located it. My frame has undercoating and 37 years of crud on it and before I attack it more aggressively I would like to make sure I am attacking the correct location. Is it directly above the rear shock mount on a '70 Convertible or is it someplace else? Thanks!
Kevin
Kevin
