red70vette
I have a 1970 cpe with a 350/300 original engine. The exhaust was replaced sometime in its history. I have recently noticed an exhaust leak at the passenger side heat riser.
I have replaced the gasket between the heat riser and the manifold but there is still an exhaust leak. The leak appears to be between the heat riser and the exhaust pipe. There is a donut shaped metal extension that fits between the pipe and the heat riser. Is there a gasket or some type of packing that goes around it. I have tightened the manifold bolts but it still leaks. I don't want to tighten them too much as they are the originals and are somewhat rusted. The last thing I want to do is break them off and have to tap new bolts in.
The heat from the leak has metled one of the A/C hoses. It even went so far as to start a fire as the hose burned. Anyone experience this? Any solutions?
