raybee
Are the exhaust manifolds stainless steel on 81's? I may need to replace one and just trying to get some facts together prior to the repair.....
Ok, awesome....I won't know for certain until the next week or two if they need to be replaced. I will contact you either way. Thanks, RayI believe that's the case. If you find that you need a pair, I have a set, but don't have the heat shields for them.
Thanks guys. I may have also learned today that the 81 manifolds are also unique in that the A.I.R. tube points "straight up". And this is the only year manufactured that way ???
OK, I'll know this week if they are needing to be replaced - you still have them?? Let me knowI believe that's the case. If you find that you need a pair, I have a set, but don't have the heat shields for them.
