Extended warranty
  • Thread starter Thread starter ddmau
D
ddmau
I recently purchased a 2000 and am arranging for an extended warranty from Warrantybynet. I'd like to install Borlas and a Blackwing filter system.
GM states this wouldn't void the original warranty but any modification that attributes to failure wouldn't be honored.
Has anyone had a problem with warranty after these slight modifications?
Thanks, Tom. The guy that did the inspection on my car for the extended warranty said vehicles with K&N filters aren't being honored because they allege the owners are not maintaining them properly. You need proper documentation in order to procve the maintenance.
Interesting point. I believe my intake is stock. A friend of mine has an '03 with K&N filters and is about to add Corsa (?) exhausts. GM tells him it will not void his warranty.
T
Right, they told me the same thing, however, if it is determined an aftermarket product contributed to the need for warranty work there may be a problem.
Might make for a most interesting decision if not at least an after the fact conversation. :hb
Again, good luck.
