M
Michael 427
This topic may be confusing but I will try to explain, my girlfriend has 1964 corvette, vin number 16694 indicates late April 1964 build, now to the confusing question, did GM have replacement engines for warranty replacement during 1964, the engine casting is 3782870, it has the Grey Stone Foundry clock by the casting date which indicates by Nolan Adams this was a mid-year change the engines being produced in Signaw, Michigan the build date is A84 the intake manifold has casting number 384459 correct for 1964 with a date stamped A-17-4 the engine pad does not have serial number the following code F0II0S, now the confusing numbers over code numbers it has X9964C stamped, does anyone have an idea on this, could it been a replacement block which would not have any serial numbers stamped on the pad, also I know there should be additional letter after the S, any ideas.
Michaael427
Michaael427
