2oldschool
After changing the trans fluid & filter in our 90 Vette (119k miles)I decided to change the diff fluid also.I pulled the fill plug & black fluid tricked out,full but needed to be changed.I removed the 13 mm drain plug at the bottom face of the diff & nothing came out. I probed the hole with a screwdriver & hit solid metal.My camera showed a solid plate at the end of the threaded drain hole. I pumped the old fluid out thru the refill hole. Anyone ever run into this before?-----(-I checked the drain plug location twice)
