yorkbeachbum
Hi Everyone,
Time to relace belts and flush cooling system. Before I get started I would like to go out and buy supplies, thermostat, hoses, etc. Thought about the belts and discovered (and remembered) that I have what I believe is a water pump drive belt. This is a small belt that rides the crank pulley and the water pump pulley only. I know it needs replacement for it is a little loose and is original. Would like to know the best way to remove and reinstall. It doesn't look like it would be too tough to install, but is there an adjustment? if so...what is the procedure?
Thanks,
Yorkbeachbum (John)
Thanks,
Yorkbeachbum (John)
