vetteboy86 said:
I finally figured out what was making noise on my car. It sounded so much like a u joint problem i replaced them twice. After inspecting suspension parts, replacing the motor mounts i narrowed it down. I have wear in the differential. A friend and mechanic told me when he looked at it that there was wear between the gears and there is an adjustment for the ring and pinion gear. By using shims you can adjust the gears in and out. So my question is has anybody else experienced this? Did you do it yourself, or take it somewhere to be done?
thanks
You are hurtin' me man, I have a kind of hollow clunk, that I can not track down! Sometimes I can't even tell if it's coming from the front or rear, maybe both. The only thing I know for sure is it's on the right side. It happens on only certain "bumps", nothing I can really pinpoint, and it seems to be worse when it's starting (?), cold, less after moving for just a few minutes.
This started EXACTLY when I put my new 17's on, but, I've changed wheels (more times than I want to admit) in the last month, and found a couple places where the 315's looked to have been hitting some plastic in the wheelwell. I "moded" those areas and it seems less.
BUT, just today, while I was up on the lift, agian, :eyerole changing yet more wheels and tires, a guy came in and was checking the play in my Ays end (diff)
He was talking to me about the same thing you are suggesting
The only real way to test this is to pull the half shafts and check the lateral play.
Now I don't want to say how many times my halfshafts have been pulled, but let's just say I'm damn sick of doing it. I put a D44 in less than 4 mos. ago and, I replaced the pinion seal on the front side and cleaned everything up, checked it all out and put the REDLINE in TWICE
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
I don't remember checking that play.
I've checked everything else five times. I don't know wher to go from here. I guess I'm gonna have to pull the halfshafts AGAIN and check the diff to rule it out. I might (will) change the rear shocks out AGAIN to be sure the new (used) Bilstien didn't bust up on me, but I can't find it!
This car is on the lift at least three times a week! If anyone knows anything, bring it on, PLEASE. I'm a little worried about running this car at 130 or so for over an hour without finding this problem first
![beer :beer :beer](/data/assets/smilies/beerchug.gif)
