No, I don't, but I do have a neat trick for you to get a quick idea what might be going on.
Wait until dark, then put the car in your garage. Make sure you have a quick access door to get in the house and or raise the main door. Raise the hood, turn all the lights off in the garage then fire it up.
If the coil is leaking out or you have bad wires you will be able to see the purple glow.
Okay, this next part is obvious.......shut the car down and get the door open so you can get some fresh air.
If you do this trick and see no glow, then you at least don't have any external bleeding off of the power.
