Fit a performer RPM manifold under L-82 hood
  • Thread starter Thread starter sscam69
S
sscam69
Well I am happy to report on my investigation of a question I had earlier.
Would the performer RPM manifold fit under an L-82 hood?
The answer is a resounding YES!
By how much?
My guesstimate is approx 3/4" -1" all the way around, but I will give you guys hard numbers tommorow. It has gotten dark and I have some weird tuning issues to take care of.
The details on my setup
-Drop base wit edelbrock top
-2.5" K&N Air filter
-L-82 Cowl hood, down know exact size but would guess 1/2"-1".
I will provide pics as soon as possible.
Frank P.
Frank, Thank you for your ongoing research on the RPM and the L-82 hood. I really want to use the RPM but I am not going to change my hood. I bought a drop base on Ebay today. All the dimensions you have given are very helpful. Fred :cool
Next questions that I will answer
How much clearance do you have exactly (static and at idle) ?
What about under hard acceleration?
The engine bounces around in the engine bay. I have only done static tests. Hopefully tommorow I will have these tuning issues resolved and will provide answers to the above mentioned questions.
Data will be provided by UTEP alumni ruler and Play-Doh!:L
Maybe you need new motor mounts ... just like the rubber in the harmonic balancer/damper ... mm's get mushy with age, heat & solvents ... perhaps a rubber-to-steel mm bond has separated ... quite common.
Read once where a wad of aluminum foil works well too ... haven't tried it.
JACK:gap
I still haven't had a chance to check just yet.
I had to take care of an issue with the heater core hoses and tuning the engine.
BUT I did have a chance for some spirited driving and I did not hear anything out of the ordinary i.e. the filter housing hitting the hood.
I don't know when I will have a chance, but I would guess towards the end of this week along with pics of course.
Stay tuned!
Frank
Is there a difference in the hood clearance between a L82 and a L48 hood. I think they are both the same but I might be wrong.
Roy
There is a big difference between the L-82 hood and the L-48 hood.
The L-82 hood has a cowl. In other words the center part of the hood is higher than the stock hood or the regular L-48. But not by much. Maybe 1/2"-1".
The Performer RPM manifold does not fit under the stock L-48 hood but since my car had the L-82 option I had some room to play with. How much was what I was trying to figure out.
Hope this helps.
Frank
p.s. I will provide pics
Thanks Frank that answered my question as I have thought of replacing my Torker Manifold with a perf RPM but didn't know if it would fit. I guess I would be better off with a reg performer manifold.
