Paddywhack
Starting to get a little overwhelmed....after a 1 1/2 years of ownership, found out its not the original engine, but a 5.0. Bought an early 80's 5.7 four bolt main, which is now at the machine shop getting cleaned, honed and all that good stuff. I know the flywheel needs to be changed due to the fact going from a 1 piece seal, 153 tooth flywheel to a 2 piece rear seal, 168 tooth flywheel. Does the clutch and pressure plate need to be changed also?;help If so, to what?;help The 5.0 is out of the vette now, but the clutch and pressure plate look very good. BTW, its 4+3 trans.
