8388
- Joined
- Jan 2, 2003
- Messages
- 808
- Location
- Texas
- Corvette
- (2) Callaway's (2) ZR1 (1) supercharged 35th
I received this email tonight from Evergreen Turbo :
Hi Sam
Sorry this took so long. But I want to make sure I find someone very qualified to machine these bearings. I should have an answer in the next couple of weeks. I need some help here. Can you see what interest you can generate in a group purchase of these bearings. This will bring the price down more if we can make 50 to 100 bearings.If the callaway guys buy them and hold on to them for future rebuilds they hold the key to getting this done. I have all the rest of the parts to rebuild these chargers. Also when they have damaged compressor wheels, the option is to machine the compressor housings out for larger flowing comrpessor setup which I have already done also. The turbine wheel journals can be turned down .010 under if damaged, as long as the blades are not damaged. Seal area's can be machined for oversize seals also. So the turbine wheels alot of times are repairable. The bearing housings can also be machined in the seal area's if damaged and completely replaced if damaged to far for .010 seals. On the .010 bearings I plan on purchasing a small quanity of these to keep in stock for more severly damaged shaft journals. Also these bearings are aluminum and will be looking at using a better grade that is more durable than the OEM bearing.
Let me know
Charlie
Those that want to get involved in this let me know, or contact Charlie at Evergreen Turbo.
!-800-275-2531
evergreenturbo@aol.com
Hi Sam
Let me know
Charlie
!-800-275-2531
