I am having trouble getting my car to crank. I have installed all of the wiring with the exception of one yellow wire that is included in the wiring harness on the right side of the engine compartment. This yellow wire is approxomately 1/8th of and inch ( I don't know guaging by sight). The yellow wire that I am referring to is too long to go to the starter. The wiring harness is usually built to within inches of the location of connection but this one is more than a foot too long for logical attachment to the starter. "help on this please".
My restoration included a new starter that was faulty from checker I reinstalled it and still no crank.
Do I need to install the seatbelt interlock system to get the system to work?
My steering column could be the problem too I guess. The ignition key will not turn back far enough to let the key come out of the ignition switch. The shifter on the automatic is in park but the key will not turn back and therefore come out.
Any help would be appreciated......;help
............................Mike in Utah
