barrett50cal
So to introduce my car, I bought it to save it from being chopped down into a hot rod car for a cheap price. The only snag was the engine, harness, and ECM was not in the car.
Then I found a 95 LT1 from a firebird for next to nothing (I bought the whole car and parted it out.) and rebuilt pretty much the entire engine and bought new corvette parts for the entire front of the engine (accessory bracket, water pump, new opti, etc.).
Once I was able to find a engine wiring harness for my car, it was from a 1995 Corvette base. The harnesses seem to be the same but after plugging everything in the car refuses to start. It will crank endlessly. The fuel pump is not coming on, and I have no spark. When I pull the codes from the ECM I get mixed results. Most of the time it will pull as C41, but occasionally it will pull as C54 and H41
I've read through my FSM for the 94 car and cant find anything standing out as wrong, however when following the flowchart for the "pulling my hair out" thread my multimeter begins pulsing between and open circuit and continuous when tested the tan wire (800 CKT) against ground. Is this normal behaviour?
Also if anybody has the pages from a 95 FSM that shows the pinouts of the harness connectors C100A to C100C, C237, C238, and C239 (pages 8A-202-13, 8A-202-16, 8A-202-17, and 8A-202-18 in my FSM) I would really appreciate being able to compare them to the 94 harness.
Please help me get this car back on the road!
Thank you.
Thank you.
