- Joined
- Jan 19, 2003
- Messages
- 3,021
- Location
- 5,800 feet above sea level
- Corvette
- 2006 'Evil Stealth Black' Roadster
A buddy in my local Corvette club forwarded an email he had been copied on regarding this subject. I've edited it to remove the original sender's name:
If it were a safety issue, they would be uniformly required across all fifty states. Clearly, they are not required in all states. And, in most states, when you renew the tag for your plates, you are only given tags to go on the rear plate.
If it were an issue of identifying someone who may have committed an infraction, given that one can only see the plate from the front, why are they printed normally? Wouldn't someone seeing you, and needing to identify you, be seeing your plate from the rear-view mirror? Why aren't the plates printed in reverse for that reason?
To this day, I have not heard a reasonable explanation for why front plates are required. Yes, I know they are required- I'm questioning the requirement itself, not whether it is legal to run the Vette without a front plate.
-Patrick
See, as I stated earlier on in this thread, while I understand that there is a requirement for front plates, and the Corvettes are not exempt from the requirement, I question the need for front plates on principle.Well, it finally happened. I was driving this morning and stopped at a stop light. City cop was opposite me. Light turned green and as I pulled out, the flashy lights went off and the cop pulled a U. I hadn't done anything wrong and thought he was after somebody else-well he wasn't...
He pulled me over and after the usual pleasantries, said "Well I guess you know I didn't pull you over for speeding. Do you know why I pulled you over?" I said no sir. "Well where is your front license plate?"
The officer was very professional so can't belittle him for that but did give me a short lecture that Corvettes are not exempt from the front license plate law, but Corvette owners don't seem to understand that. There was some more lecturing and he said finally, "Tickets and fines don't seem to do much good for most Vette owners rather than just a verbal warning-how about you?"
So as much as I hated it, I said I would put mine own and got off with a verbal warning. Did some errands and then went home. Took me 30 minutes to find the front bracket for the plate and after shedding some tears, put on my front plate for the first time ever. Then took me another 30 minutes to find the registration sticker. I always thought that Vette owners didn't get pulled over for no front plate unless they were doing something else (speeding, smokin tires, etc), but now I have been proven wrong.
Now Depressed In Minnesota
99 Black Roadster DRM RSR 500
-Patrick
