My Corvette has started making a noise that I can best describe as a slapping noise when driven over uneven ground, such as a rough parking lot. It is coming from the front of the car, and I don't notice it at higher speeds. I lifted the car up and was able to reproduce the sound (I think) by grabbing the front and rear of a front tire and shaking it. Shaking top and bottom does not produce any noise, although there is a slight amount of play in the driver side lower ball joint (none on passenger side ball joint). The driver side inner tie rod (under the boot) has a little play when shaken, but the noise there is a muffled thud, not the slap.
No other joints have play. The steering rack mounting bolts and all other bolts are tight, with no sign of slipping. Rubber bushings, sway bar mounts, etc. all look good.
My theory right now is that the noise is coming from the rack. The car drives fine, with no unusual feel in the steering wheel. It doesn't feel like there is too much play in the steering. When I had the car in the air, I didn't think to turn the tires left and right and try shaking them while turned.
Any suggestions on the source of the noise?
Thanks,
Ken
Thanks,
Ken
