I'm building a 1966 resto-rod with a tube chassis that accepts C4 components. Is there a major difference between the 1985-87 and 1988-96 front steering geometry enough to make me choose the latter over the former for sure? And other than the 88-96 caliper being 2-pistons, anything else different between the brakes? Are the 2-piston calipers that much better than the one-piston? I don't have plans to upgrade to 13" rotors/calipers since the wheels will be 16" and the big brakes won't fit. I won't be using the spring or the sway bar either.
The frame accepts only 1985-87 upper A-arms, is there a problem in using those A-arms with the rest of the 1988-96 set up?
Finally, any suggestions on the steering rack? Any major differences there between years?
Thanks in advance,
Islander
Thanks in advance,
Islander
