Barnacle Bill
New member
I started to get a slight shimmy from the front end of my 94 convertible and decided to do a urethane bushing up grade and rebuild the front suspension. Replaced upper/lower ball joints, tie rod ends, replaced bushings in lower A-arms, steering rack and sway bar. Just picked car up from the alignement shop and discovered the shimmy problem is worse. Any bumps or un-smooth roads seems to trigger the problem. Car has FX3 suspension. Any ideas on how to correct this problem.
