The bar is 3/4" diameter, but the hole in the split bushing is much smaller than that in the free state; the bracket really compresses it when the bolts are torqued (usually have to use a jack on the bracket to compress it enough to get the bolts/nuts started).
The reason I asked is because Im doing a body off. I want to replace my bushings but Im not sure what to buy. Do the bushings come in different sizes ?
