How do I get to the bulbs in the front turn signal housing of my 97 corvette? I can't seem to figure it out. These bulbs keep burning out - due to moisture I think. Should I just replacing the entire housing?
I access mine through the open Headlight hole, remove the headlight bezel first.
You should be able to repair your turn signal housing, typically the heat from the bulb melts the housing a tad bit and allows moisture to get in. It can be sealed with silicone or something suitable...
