First, when I say the Edelbrock carburetor has trouble with fuel control, I'm talking about the Carter-AFB-derived, "Edelbrock Performer" four barrel. It's an ancient design. Admittedly, Edelbrock has made some improvements but the core problem, fuel slosh under lateral acceleration and braking, and the problem that ended GM's use of the AFB in 1964, is the problem that can cause it's problem when used on Corvettes. The harder you drive your C3, the worse the problem becomes.
I had a pair of Edelbrock Performers on a modified Big-Block back in the early 90s and it was a nightmare of driveability problems and that was with extensive tech. and parts support from Edelbrock. Those performers would go way, way rich in hard cornering or hard braking. The problem with braking was so bad that the engine would consistently stall at the end of a hard stop.
As for the Quadrajet, while understanding any automotive device makes the user experience better, one does not need to be an expert on how the Quadrajet works to know it is the best four-barrel ever made for street use on performance engines making 450-hp or less. It is far better than any AFB or AFB clone and better than a Holley.
With proper tuning it make power as good as Holley but drives better and gets better gas mileage. It makes better power than most of the AFBs and drives much better and gets better mileage.
Sadly, the Quadrajet has been much maligned by those marketing aftermarket carburetors and because it is, admittedly a more complex carb then an AFB or a Holley, the culture of hot rodding what it is, the urban legends about the QJ have also contributed to it's sometimes bad reputation most of which is B.S.
I used a Quadrajet on my 71 Coupe until the engine went past the 500-hp level. Up until then, my QJ which was properly tuned for the motor, ran hard, never presented a problem during cornering and braking and got great mileage.
While I think the Edelbrock Performer carburetor is not a great choice for a car that corners or brakes hard, it actually is a pretty good drag racing carb. And finally, that the Performer Series carb is not my favorite product doesn't reflect badly on the rest of Edelbrock's product line. The famed maker of a wide variety of aftermarket performance products has a lot of other really great products.
