garyg
My 1988 C4 would start then shut down and was indicating a code 36 on the OBD readout, this is a MAF problem. I removed the MAF unit and cleaned it with CRC spray and remounted it. OBD code now reads 12 which is normal. Car would start strong then shut down, I expected a blocked fuel filter so after removing the fuel pump fuse, relieving fuel pressure at the fuel rail I installed a new fuel filter. Now the car cranks but no indication of firing, I suspected fuel pressure hasn't built up in the system, but still not firing.
Any suggestions?
Any suggestions?
