Y
Yellow96
What is the best product to use in the gas tank to clean the fuel injectors? How often should you use the additives?
Thanks-----John
Thanks-----John
Rich 94 6spd said:B17crew i'm with you.
"Multec injectors were present on all ‘89-’96 Corvettes. These are self cleaning disc injectors. The injector windings are cooled with fuel, so harsh injector cleaner will damage the windings and short out the injector."
I won't clean mine because of the possibility of causing damage to the injector windings.
Rich
Eagle85C4 said:I tried the Sea Foam, it did not work very well....then I tried the Lucas Brand Injector cleaner and I was very surprised at the performance I picked up after using it. Made a big difference...
