emf1367
My car runs fine at idle and up to 70 mph (didnt try faster) without any problems if you slowly depress the gas pedal. However if you press too fast it goes for a moment and then cuts out. It will die if you dont back off the gas.
A service tech said it was a fuel starvation problem, maybe a pinched line or something. I checked the fuel pressure and it is good so it'e either a fuel pump (which is brand new) or something in the line.
My idea is to install a temporary fuel hose running directly out of the fuel filler tube to the fuel pump. If the problem disappears then I've isolated it to the fuel pick up line.
The thing I discovered is there are two lines fed to the pump from the tank. I thought the smaller one was a vent line, however when I unhooked it fuel poured out of it. So I guess one of the lines is the return line and the other is the feed line.
If I bypass the main feed line (the larger diameter one) and run from the filler tube to the pump will the system still work?
And help would be appreciated.
