9
94Roadster
About a month ago my 94 Roadster with the LT1 wouldn't pop right of and start. So I bought a fuel pressure regulator gauage and watched the fuel pressure at 40 PSI and then when I shut the engine down, the pressure dropped as fast I could count down! I then unplugged the vaccum hose from the fuel pressure regulator and it just poured out gas. So I replaced the regulator and it then start perfect.......for about a month. Tonight I put the gauage back on and it while running the pressure was at 40 PSI and when I turned off the engine the pressure stayed there about 45 seconds and then dropped to about 38 PSI. I pulled the vaccum hose off and gas was pouring out again! It looks like I have another bad regulator. My question is: What is causing my fuel pressure regulators to go bad? It's a Bosch part and they aren't cheap. Is there something else I need to check before I put another regulator in? Did I just get lucky and have the new one go bad? Help!:confused
