Need to know the correct fuel pressure for a 95 CORVETTE automatic using an adjustable pressure regulator. Please specify if the vacumm line should be off or on.
PLRX787 said:Thanks Heartbeat!!
Off. UR setting a maximum value, reduced by vacuum.PLRX787 said:Please specify if the vacuum line should be off or on.
WhalePirot said:Off. UR setting a maximum value, reduced by vacuum.![]()
