74bigblock
This is an aside from my other post "Bogs at full throt".
For some reason... after installing new pump, the rod that comes off the cam shaft is frozen. It is not acuating the pump when it is installed. It does not fall down when the pump comes out, nor can it be pulled out with fingers. I am thinking of getting some needle nose vise grips on the little sucker and yanking it like a tooth, then just replace it. Has anyone encountered this problem before and if so, how did you solve it?
Dave
Dave
