Help! fuel pump related
clearwater, fl
1990 hatchback dark red
I have a 1990 base coupe (red) 6 speed, 37400 miles.
Problem is fuel pump, when turning key on, pressure instantly climbs to 45 lbs, then drops instantly when fuel pump stops. Car will run after long cranking.
I checked pressure at the tank outlet and the same occurs, pressure instantly climbs to 45 lbs then drops to zero when pump stops.
Do I need a new fuel pump?
follow-up
No.
Is this your compaint? Are there other symptoms that bother you?
I also had hesitation and stumbling on acceleration, I think fuel pump is problem since pressure did not rise above 45 lbs on hard acceleration, I ordered a fuel pump that is coming in this afternoon and will advise after I install
