georgekthompson
I have a 1990 base coupe (red) 6 speed, 37400 miles.
Problem is fuel pump, when turning key on, pressure instantly climbs to 45 lbs, then drops instantly when fuel pump stops. Car will run after long cranking.
I checked pressure at the tank outlet and the same occurs, pressure instantly climbs to 45 lbs then drops to zero when pump stops.
Do I need a new fuel pump?
