boomdriver
I pulled my dead fuel sender :cryover the weekend to see lots of rust on the underside of the top plate and the steel tubes. Pretty discouraging to see all that crud IN my tank. (sender contact broken off, new assy required)
My question is, does anybody know of a coating or some material that can be applied to the metal parts of the pump filler-neck & tubes, to prevent rust? Obviously something that will survive in gasoline?
Next question, can the rust be cleaned away with bead blasting or an acid wash and the parts be used again and NOT rust immediately? were they supposed to be galvanized to prevent rust? or just plain mild steel?
As long as we are forced to run with gas that has alcohol, water is going to be an unwanted "extra" that will continue to cause rust and contaminate our fuel systems. My new injectors are not going "in" until this is resolved.
Any ideas?;help
Any ideas?;help
