mick_s3
I filled the tank this morning and the gauge worked fine all the way to work. On my way home it worked fine untill the gauge dropped just a bit below full. I cleared the codes, works again.
The last time this happened, it was the same deal, and the code clearing worked for a day, then it would throw the codes again. But once the tank down to about 1/2 it started to work fine untill it was down close to E, a span of 4 or 5 days.
Seems there is a "bad spot" which is between just under F and a little over 1/2 a tank.
Seems kind of weird, I guess I should just stop filling up and keep the tank a little over 1/2 ....
Also, I added a bottle of Techron to the tank and it does seem to help. I notice a little better response and what little hunting idle was left after the plug and wire change is all but gone.
Mick
Mick
